Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Installing XP seal offs efficiently
  1. #1
    Am going from having done Zer0 seal offs in my electrical career to doing a bunch of them! I need to be able to install them fairly quickly now sooo I could use some tips and ideas on how to fill them with Chico as fast yet as effectively as I can. Any help?
    Thanks
    Pete
  2. #2
    Join Date
    Feb 2005
    Wilmington, NC
    Posts
    4,500
    I've heard Crouse-Hinds has an expoxy sealing compound you don't have to mix. I've been told it goes in quickly and clean, but you really pay for that.
    Another nice trick is to take the screw cap with funnel from a 1-Qt lube bottle, and an empty plastic soda bottle. Clean the soda bottle, then after you mix the Chico, pour it into the soda bottle and install the cap from the lube bottle onto the soda bottle. Makes pouring the sealoff easily controlled.
    Packing those suckers is the most time consuming part. If you don't do it correctly, the Chico goes down the conduit. Make sure your packing doesn't come up too high in the sealoff. Using combo (horizontal/vertical) sealoffs in the vertical is a pain in the butt.
    Good luck.
    Lou (wannabe economist)
    If you relentlessly pursue perfection, you will eventually catch excellence.
  3. #3
    Join Date
    Aug 2006
    Cincinnati
    Posts
    271
    and make sure the conductors all have some packing around them- each individual one- so you don't have voids where they're twisted together
    You can't scare me- I have teenagers
  4. #4
    Join Date
    Apr 2007
    Colorado
    Posts
    154
    Smile
    Paint or mark the hub to indicate it has been filled. Easier to track completion that way.
    Remember the fill rules, 25%. Not your customary 40% as in conduit fill. Expanded fill seals or oversized seals with an RE may be a good option.
    And please......don't get the Chico on the threads. It makes it hard to inspect......
  5. #5
    Join Date
    Feb 2003
    Illinois
    Posts
    23,542
    I have never seen one without Chico on the threads.
    Don
    Don, Illinois
    Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
    (All code citations are 2017 unless otherwise noted)
  6. #6
    Join Date
    Apr 2007
    Colorado
    Posts
    154
    Ahhhhh
    So you're the guy! I'm watching for you.:wink:
  7. #7
    Join Date
    Jan 2006
    Cocoa, Florida, USA
    Posts
    318
    We always (neatly) allowed some chico to spill on the outside of the fitting. Never, in hundreds of sealoffs, were we questioned. The QC witnessed the integrity of the fiber packing on the first few units, and we were good to go!
  8. #8
    Join Date
    Jan 2006
    Cocoa, Florida, USA
    Posts
    318
    'quickly' and 'sealoffs' are mutually exclusive words . . .
  9. #9
    Join Date
    Aug 2003
    Northern cold country
    Posts
    2,621
    lol..I love it seal offs are not a speed job..they need quality time, so enjoy.. One goes sweetly and the next one sucks. it is all about the pack so get a #2 pencil w/eraser and use the eraser end to pack the fittings. depends on temp to how much you can mix for pouring..I like to pack several and then go through and pour them..but always mark your fittings..
    Life is temporary, heaven is forever. live life like it is your only chance to make a difference..
    to do nothing is the surest way to achieve nothing..
  10. #10
    Join Date
    Jan 2006
    Cocoa, Florida, USA
    Posts
    318
    seal offs are not a speed job..they need quality time. One goes sweetly and the next one sucks
    Very well put.
    Don't recall what Means allows for a sealoff, but it isn't enough.
    Never heard of the #2 pencil eraser trick.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
