Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Any body bond or ground the gas meter
  1. #1
    Join Date
    Jan 2008
    NC & IN
    Posts
    3,295
    Arrow Any body bond or ground the gas meter
    Does the 2008 NEC require that we bond or ground the gas meter in a sfd.
  2. #2
    Join Date
    Jan 2004
    Right here.
    Posts
    12,326
    I don't. Matter of fact, the gas company in my area claims that will mess up their cathodic protection system. I don't know if that's true or not.
  3. #3
    Join Date
    Jan 2008
    NC & IN
    Posts
    3,295
    Whats a cathodic protection system?
  4. #4
    Join Date
    Nov 2007
    massachusetts
    Posts
    3,166
    its ok to bond gas pipe but you cant use it as a GEC. local codes might be different. i dont bond the gas pipe.
  5. #5
    Join Date
    Aug 2006
    Miami Fla.
    Posts
    7,402
    Quote Originally Posted by buckofdurham
    Won't it be bonded through the EGC of the appliances?
    Second to last sentence of 250.104(B)
  6. #6
    Join Date
    Jan 2008
    NC & IN
    Posts
    3,295
    Angry
    I'm wiring a house in Chatam County NC, I,m told the inspections require you to run a seperate ground from the main panel all the way to the meter. This house has a 400 amp service and the gas meter is on the other side of the house.
  7. #7
    Join Date
    Nov 2007
    massachusetts
    Posts
    3,166
    Quote Originally Posted by chris kennedy
    thats how its bonded. but i dont physically run a conductor and bond it to the service.
  8. #8
    Join Date
    Mar 2006
    Westchester County, New York
    Posts
    8,221
    I believe part of the issue in regards to bonding of gas pipes today has developed due to CSST (corrugated stainless steel tubing - the flexible gas piping - Gastite, Wardflex, etc...). The manufacturers have their own installation instructions that go beyond the NEC requirement of 250.104(B).
    NYS has put together a committee to deal with the situation, and if I am not mistaken, the state wide code will be amended to deal with the issue, plumbing and electrical.
    I can also say that one of the methods of dealing with this in NYS may ultimately lead to the banning of CSST installations in the state.
    I will let you guys know when I hear...I have been invited to sit at the meetings.
    Instructor, Industry Advocate
  9. #9
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,516
    I work in chatham county , NC also-- you are talking about CSST or gastite gas lines. Yes you must bond that back to the panel.
    Edit: I guess I should have read Pierre's statement first.
    Be careful in Chatham I have had them tell me to bond the CSST pipe with a #4 to the ground rod. This, of course, is not what the manufacturer states. Unfortunately I cannot get an installation instruction that is consistent. I refuse to bond them now. I tell the gas people, you install it , then you bond it. I do not want the liability.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  10. #10
    Join Date
    Jul 2007
    Mooresville NC
    Posts
    22
    In Manalapan NJ. we run a number 2 copper to gas meter if the water pipe is plastic. Even if we have a CEE we still have to do it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
