Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Weatherhead height
  1. #1
    Join Date
    Feb 2008
    Posts
    14
    Weatherhead height
    To be in compliance with the 2005 NEC, how high does the weatherhead need to be above the roof-line of a residental home?:-?
  2. #2
    Join Date
    Mar 2008
    Indiana
    Posts
    2,547
    Quote Originally Posted by control4it
    the weatherhead doesnt have to be above the roofline...
  3. #3
    Join Date
    Feb 2008
    Posts
    14
    Is there any min. height that the weatherhead needs to be above grade?
  4. #4
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,860
    Quote Originally Posted by ultramegabob
    but, if it is, there is no "quick" answer. You really need to look at 230.24 as there are a number of varibles which make the correct answer anywhere from 18" to 8 ft.
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  5. #5
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,860
    the weatherhead should be at or above the point of attachment, and since the minimum clearance for overhead conductors is 10 ft., the answer, I believe, is 10 ft. (230.26 somewhat confirms this)
  6. #6
    Join Date
    Feb 2008
    Posts
    14
    Is the weatherhead height based on height above grade?
  7. #7
    Join Date
    Mar 2008
    Indiana
    Posts
    2,547
    you need enough height on your service mast to get proper clearance for the service laterals.
    http://www.cinergy.com/customerproje...ual_sec300.htm
  8. #8
    Join Date
    Dec 2003
    california
    Posts
    59
    weaather head height
    HI.. I am in the sunny state of Calif & as we have PG&E. They require the minium to be 13' to the bottom of the head off finish grade.. Just some info from here. so? maybe check with the local poco to see what they reqire.
  9. #9
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,860
    I would think, normally, yes, that would be the reference.
    but, obviously, not necessarily so. I picture a weather head on top of a riser on a penthouse built on top of a 4 story parking garage :-)
    now 60 ft above grade. :-)
  10. #10
    Join Date
    Jul 2005
    Upper Jay, NY
    Posts
    2,079
    also, allow for drop conductor sag. The low point should comply with 230.24(B).
    Answers based on the 2008 NEC Edition when I think to grab that one.
    What you are, you are by accident of birth; what I am, I am by myself. There are and will be a thousand princes; there is only one Beethoven. Ludwig van Beethoven
Posting Permissions
  • You may not post replies
  • You may not edit your posts
