Got a call from a customer who we just finished installing a "whole-house" battery backup. The system is about a week old and has performed normally until this evening.
The unit is such that the 200 amp feeders get routed directly to it, and it has an automatic transfer switch for when there is an outage. This is not our first install of the unit. It is a high quality unit.
Customer described flicking lights, smelling an electrical smell in the garage, and appliances acting weird.
We showed up and everything looked fine leading up to the main panel. Voltages were in the correct locations and correct values at the battery unit and at the main house panel.
Heating loads (240, no neutral) worked perfect. As we turned on 120 loads one by one, a voltage imbalance began to occur. Resistive loads like an electric kettle and toaster would not work at all. As we turned lights on one by one we heard a louder and louder humming noise coming from what appeared to be the large lugs in the battery unit where the utility lands. As the load grew, lights flickered more, as the humming noise intensified.
I am just wondering what those symptoms point to? A neutral problem apparently, but I have not seen enough of these problems to be able to recognize what is happening.
We were able to bypass the unit pretty easily but we'll have to return soon to figure out what is going on.
Thanks for your input in advance!
