ptonsparky
Tom
- EC - retired
Actually, Au is gold. Ag is silver (Argentum). But I cannot recognize silver wire under the insulation.Ag is the symbol for "Gold" on the periodic table of elements.
Looking closely at you images for gold wiring, but don't see any?
Had to save images, and enlarge using image software.I should have asked how many NEC violations.
1) Direct buried cables protruding above ground without raceway protection.
2) Custom controls cabinet not listed, or field approved
3) Cabinet raceway missing thread bushings
4) Don't see grounding bus for green wires
Can someone explain those strange looking 2-wire connectors?
You know it could not be that simple here!I should have asked how many NEC violations.
Yes.The two wire connectors appear to be Polaris type splices?
I think the main issue is what conductor types are still fairly conductive after they oxidize. Aluminum oxide not significantly conductive at all, copper not too bad and silver and gold presumably don't deteriorate to any significant amounts when oxidized, conductivity wise for most uses from my understanding.Except for the fact that it tarnishes, silver is supposedly a better conductor than copper... Gold is nice because it doesn't tarnish. Of course, Gold has to be alloyed with other metals because gold is lousy in mechanical properties (relatively speaking).
My best guess is service conductors are spliced, the other service "tap" goes to the "other panel" which is probably a control panel for a center pivot irrigation machine. Those control panels usually have a main fused disconnect within them but are not normally suitable for use as service equipmentSince you didn’t give us a full picture, there is probably more, doubled up wires on the starter, feeding the panel on the other side? Service conduit too short, can’t see where the spliced utility feed goes.
Ok, now I can see the control wires are just run behind the taps, not in them.
