Joncampos3
- San Antonio, Texas
- Electrician
Hey everyone. I’ve heard different ways of putting a MC connector on hospital grade MC and what are you suppose to do with the non insulated ground.
Yup, but you can use them if you want to.And no redheads for MC.
No, you don't have to. You can if you want to but not necessary or required.So you don’t have to fold the aluminum conductor back behind the connector?
Like Roger said no. I find it harder the install the connector with that big #10 wire in the way.So you don’t have to fold the aluminum conductor back behind the connector?
It is MCAP and is listed for healthcare use. It is an alternative to the old hospital grade AC.The cable with the # 10 alum bond is not Hospital grade is it? Per the OP
Except OP was asking about health care cable, which will also have a green conductor that will need to be terminatedI wonder why so many electricians are reluctant to just cut the wire off at the armor? I've seen guys tie them on to the EGC bus in panels, attach them with ground screws to metal boxes, connect them to devices, etc. The reason you use this type of cable is so that you do not have to terminate any EGC's which saves a ton of labor cost.
All healthcare cable will have both, it's the only way a cable assembly can comply with 517.13(A) & (B)Never seen Health Care with an insulated green and a #10 Alum.
Have you seen HC cable without a green, or just AC cable?Never seen Health Care with an insulated green and a #10 Alum.
I have not seen the HC cable in Roger's link with the full sized alum bond wire. I notice it does say to use the listed connector, because of that larger bond wire. I said I have seen MC with no green wire at all and an over sized alum bond. I thought it was MCAP (ap for all purpose). It was used in a retail clothing store. I will have to check if it is called MC or AC.Have you seen HC cable without a green, or just AC cable?
