mbrooke
Batteries Included
- United States
- Technician
Does anyone know the NEC's reasoning behind expanding GFCIs to equipment over 120 volts? Hard wired equipment? Industrial equipment?
I believe there were some instances of electric shock that the CMP believes can be avoided with GFCI protection on circuits of 250 volts or less.
Receptacles only I believe.
Residential Dishwashers are a different breed. I’ll have to look to see if commercial units need GFCI.
Spa is a good one...
Believe hard wired 208 or 240 volt ranges and dryers do not need GFCI protection under the 2020 NEC but think this is a mistake. GFCI'S can be a pain in you know where but safe thousands of luves a year.Does anyone know the NEC's reasoning behind expanding GFCIs to equipment over 120 volts? Hard wired equipment? Industrial equipment?
Dishwasher was added because of a product issue that should have been taken care of by product recalls, it wasn't even shock hazard that triggered this but rather component failure that can end up starting a fire, but GFCI can respond to that failure.Residential Dishwashers are a different breed. I’ll have to look to see if commercial units need GFCI.
Any chance breaker manufacturer profits had anything to do with it?Does anyone know the NEC's reasoning behind expanding GFCIs to equipment over 120 volts?
You mean the same ones that were major players in getting AFCI requirements into code?Any chance breaker manufacturer profits had anything to do with it?
What they going to do if someday they are mandated to do some sort of recall on products that are already 10+ years old.
Has happened with airbags and other safety components in some older vehicles.
The recall involved putting a couple of tie wraps on the wires so the leaking heating elements wouldn’t drip on the components. I know, I had one.Probably so
Whirlpool Settles Dishwasher Fire Lawsuit With Offer of Rebates and Repairs
Consumer Reports has the settlement details of a class-action dishwasher fire lawsuit involving Whirlpool, KitchenAid, and Kenmore dishwashers.www.consumerreports.org
for what reason? Recall to the entire line or just certain lot numbers that maybe were discovered to have a defect? They do recall other products within certain production dates at times because they found something defective that likely effected the entire lot.I think Square D had a blue or green button AFCI on recall a decade ago.
