mbrooke
Batteries Included
- United States
- Technician
Why are capacitors listed 380 and 440 volts? What permits them to be used on a 480 volt supply?
Nominal voltage?Why are capacitors listed 380 and 440 volts? What permits them to be used on a 480 volt supply?![]()
www.umatechnology.org
umatechnology.org - umatechnology Resources and Information.
umatechnology.org is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, umatechnology.org has it all. We hope you find what you are searching for!www.umatechnology.org
Nominal voltage?
370 v and 440 v capacitors are commonly found in single phase condensing units and heat pumps in start and run applications. The voltage rating is the maximum working voltage and there is no harm in using a higher-rated part than the original. Critical is the capacitance, which should not deviate by more than +/- 5%.
There are caveats to what you say, to be aware of.370 v and 440 v capacitors are commonly found in single phase condensing units and heat pumps in start and run applications. The voltage rating is the maximum working voltage and there is no harm in using a higher-rated part than the original. Critical is the capacitance, which should not deviate by more than +/- 5%.
A cap rated for more than 480v(rms). Caps are peak V items, when the diff charge on plates gets too high, it will punch right through the insulation, arc flash, and many times explode. Something like a 750v rated cap, or one that says "rated for 480v(rms)".So what do you put in 480 volt units?
If you mean using a 370 where a 440 was, it would only be the case of no-start is the cap blew up, given the MFD was the same, etc.I should have asked how you are using it.
In motors the counter emf generated in the motor windings while it is running is the problem. We can replace the 370 with a 440 but not the other way around. It may not even start the first time with the wrong voltage.
OP, what is the application in a 480v circuit? Do you have a schematic?
A 440 V starting cap is for single phase. It is usually an electrolytic design and NOT continuous duty. The fluid will boil and it will vent or explode after about a minute. They are only intended for 10 second operation.
Surge testing is normally 200% of rated on most equipment so I would expect it to easily survive 480 V, for a LITTLE while. And since a starting cap will run $20 while a continuous duty power factor or filtering cap will run a few hundred at the same size it’s easy to make a mistake. Capacitors can be one of the more baffling parts of electrical work.
We just saw a single phase 480 volt motor not too long ago. First for me. IDR caps on it.You have a 480 volt single phase fan motor???
