James L
- Kansas Cty, Mo, USA
- Electrician
I wired a remodel project at an old Ryan's Steakhouse, and one of the tasks was to revamp the outdoor lighting (and switching).
The original wiring scheme has a 100-amp feed from the MDP to a 100 amp contactor which then feeds to a 100-amp panel with all the outside lighting circuits coming out of there.
The contactor was originally wired to be controlled with a photocell and a time clock. At some point, the photocell had been disconnected. It was still there on the roof, however.
And this is where my work came in.
I installed a new photocell, and noticed that it did not turn off. I assumed it was defective, so I took it out and replaced it. Same thing, not turning off. So I got another photocell of a different brand, and same thing - not turning off. So I bought a different type of photocell and same thing, not turning off.
I have no idea why no photocell will work properly with that contactor, but I figure that's why the original photocell was disconnected.
So I decided to changecthe time clock to a 1900 box and install a programmable timer. It worked perfectly.
But now the restaurant has been open for 2 weeks, and the owner sent me a couple of videos. The contactor is cycling on and off about every 10 seconds - 5 seconds on and 5 seconds off. All evening.
I'm guessing something in the contactor is bad somehow, but don't know what. Bad coil? It doesn't trip the breaker. Any ideas?
