Jerramundi
- Chicago
- Licensed Residential Electrician
Trying to provide an estimate for a job and part of the run is underground PVC that stubs up to and through the building to a timer, then transfers to EMT. The portion of PVC that is visible above ground is painted.
I was just wondering if anyone had any tricks for identifying existing PVC.
I was able to determine it was 1/2" PVC via it's Outer Diameter (OD), but have no idea if it's Schedule 40 or Schedule 80.
The only (2) things I can think of are (1) dig down until I find some insignia on the PVC... or (2) disconnect/cut a section and measure the Internal Diameter (ID).
I'm trying to compose the estimate before I have to do any actual digging and or tinkering with the existing, but if the above (2) options are the only available methods, I might be stuck...
Thoughts?
Thoughts?
