Peter Furrow
We’re not born humble, we’re born to be humbled
- Cape canaveral Fl
- Electrical contractor
My technician responded to a service call today at a condominium. The new pool pump motor installed by the on-site maintenance man was extremely hot to the touch. The last motor burned up.
Power is being delivered from the main distribution panel Reading 208 V. Approximately 200 feet downstream is the pool equipment room that was receiving 203 V to the pool pump motor. (Obvious voltage drop).
The pool pump motor nameplate rating says 208 -230v FLA 24Amps.
However, our actual reading was 203 V & ammeter read 30.4 Amps running load.
The 200 foot feeder conductors is #2 CU.
(Sufficient to handle the load.)
Obviously this voltage drop is causing the increase in the amperage draw.
What do you think is the best way to resolve this? How can I raise the voltage to the
208 and the 230 V requirement mentioned on the nameplate?
I think they’re gonna burn this new motor up if this voltage doesn’t get resolved .I just don’t know what to do at this point. To top it all off we are extremely busy right now but I want to take care of them. Ugghh..
