Fred B
- Upstate, NY
- Electrician
Just starting job that was left unfinished (or at least uninspected) and contacted inspector about some questions and got two different answers from two inspectors. New homeowner wants the old wire that hadn't been updated replaced (old brittle cloth wrap and bx) and receptacles with no grounds. No problem with fixing that, but question is do I need to add AFCI breakers on all circuits that would require them as if it was new install or leave old standard breakers and just update the wire? There is no plans for any added circuits or additional outlet receptacles? One inspector says most definitely have to add AFCI on all the applicable circuits. Other inspector says it's a repair no need to change what is there.
If anything by putting grounded wire in it will make it safer for use with grounded tools or appliances compared to using those cheater adapters on the end of the plug.
Which inspector is right? Adding all AFCIs would add at least $1500 to the job, if I can even get them. Not that cost is a problem just getting them might be.
