HELP!!!
I hired an electrician to put in a dedicated breaker , wiring and receptacle for 48 amp kiln. The manufacturer specs called for a 60amp breaker to be installed yet he installed a 50amp breaker bc the plug was is a 50 amp plug . The inspector believes this is correct as Well. The manufacturer (l&l) maintains that nec code requires the 60 amp. the kiln 240v/ single phase
I’m caught. Will the 50 amp suffice? Any advice is greatly appreciated .
