Javier Unzueta
New User
- Miami/Lady Lake
- Painting Contractor
I’m building a new home in Lake County as owner/builder. (My father is an active GC for over 55 years and I have been involved in all the disciplines of the company for 30 years but have been out of touch with electrical for about a decade now) I would like to run numerous cat6 cables for the purpose of future proofing my new home (motion sensors, led, networking, poe cameras etc.)
I will be complying with the WORING INSTALLATION section of the NEC rules for low voltage wiring as IF they were energized.
Question: what, if anything does the code say about the feasibility of installing non-energized cat6 cables throughout the walls? They will all be terminated with rj45 plugs and behind blank plates in their proper boxes. In other words, does the NEC forbid non-erergized wires installed in a new construction (for future use)? In your experience, do you think there be a problem at inspection time.
The reason I am asking this is that the plans have been drawn up and approved but the architect did not include any low voltage cables in the electrical plan stating that it did not need to be there.
Do I need a plan revision or is this a non-issue? Will (in your experience) an inspector disapprove a rough for non-energized wires properly installed that are not being used and do not in any way interfere with the main electrical system?
