Per the page: "As you produce solar electricity, it enters your home through the standard power outlet and is split up between any appliances using power and the home battery." Maybe the U.S. version is different.The inverter wont supply power to the male prongs unless its plugged in. It appears that it is designed to NOT backfeed the grid. Kinda cool actually, as long as people realize how far (not far) 320 watts gets you, and how critical a substantial clear view of the sky is.
Im not sure if you are disagreeing with something I said. By "grid" I meant the utility grid outside of the building.Per the page: "As you produce solar electricity, it enters your home through the standard power outlet and is split up between any appliances using power and the home battery." Maybe the U.S. version is different.
Im pretty sure they have been available for a long time. I know you can get the cheap Chinese plug and play grid tie inverters, not sure if they are listed though.Makes me wonder if they're going to engineer a true 120-volt inverter. Most inverters are 60/60 volt. If you try to plug one of those in, the service bond will short it out and poof..... there goes your inverter.
What makes you think it will stop at the service panel? There's no provision for disconnecting the house from the "grid".Im not sure if you are disagreeing with something I said. By "grid" I meant the utility grid outside of the building.
It says:What makes you think it will stop at the service panel? There's no provision for disconnecting the house from the "grid".
what would? To not send power back into the grid? Seems pretty straightforward. Or are you questioning whether doing so negates the need for an interconnect agreement?That would be quite a hat trick.
what would? .......
100% guaranteed that they are not.Im pretty sure they have been available for a long time. I know you can get the cheap Chinese plug and play grid tie inverters, not sure if they are listed though.
A careful reading of the "system" description recognizes the device which attaches to the service panel and detects power backfeed and sends a WiFi throttling signal to the panel/inverter. Presumably this involves a current transformer set with split cores and a non-contact voltage phase sensor or the required plug-in power connection. (Otherwise or arguably in all cases, it would have to be installed by an electrician.) I works with the battery (also WiFi linked) to tell the battery to charge only when there is excess power available from the solar panel?Backfeed-connect an inverter to any random receptacle and NOT have it backfeed the utility.
If the grid is down, using the system for emergency power would require manually opening the main breaker.
The whole thing seems far too complex and expensive to be justified by a mere 300 watt supplemental power source. No mention of adding additional 300 watt units.
I also have doubts about proper mounting of the solar panel for decent power production. The "balcony" they mention would have to be south facing.
All it has to do is prevent reverse energy flow on the incoming mains. That is easy.OK, explain how it differentiates between the 120v coming in on the mains and the 120v being produced by the inverter. There's several quintillion electrons flowing through the conductor and some snap-on device magically knows which ones "don't belong and should be stopped from going one direction".
I'm lost. Keeping energy flow going only in one direction is done all the time. Just need some communication between the inverter and the batterySo you're going to rectify the AC coming in? Do tell, how does a 'snap-on device' accomplish that?
