mbrooke
Batteries Included
- United States
- Technician
Can we just agree that the S=R1+R2+R3+R4 is to high in back stabbed connections? Being the cause behind most residential electrical fires vs arcing IMO?
I’ve argued that for years. Very poor connections. Sometimes works ok for light loads in houses with no vibration but nothing consistent. Screws are better, pigtailing is best. I pigtail.
So you are saying pigtailing is not good? I have had virtually zero issues from pigtailing. I have seen some receptacles burn from screw connections if circuit is heavily loaded. Connection is good but a geavy load on one device is a heavy load on all others up line of it. Pigtailing insures that each device only carries its own load.Screws are a cold weld, with astronomical surface area.
All it takes is the slightest resistance in any splice or connection and a run away effect will take place where heating will cause series R to go up, causing more heating, more R even more heating to the point the connection is visibly glowing.
YES!!!Can we just agree that electricians shouldn't be calling receptacles, plugs?
I didn't realize that EGC must be pigtailed. that being the case why are we allowed to not pigtail HOT and NEUTRAL? IMO this should be the standard. I do a lot of troubleshooting and "back stabbed" connections on a receptacle are the cause of many problems.IMO pigtailing is the best method. The EGC must be pigtailed and cannot be back stabbed for a reason.
That's why devices have only one EGC screw.I didn't realize that EGC must be pigtailed.
mh
But the reason has nothing to do with safety and everything to do with paranoia. The reason you are required to pigtail EGC's is so that if you remove the device you won't open the EGC connection to the next device. backstabbed connections are every bit as safe as any other kind of connection if it is done correctly. You can make any kind of connection unsafe if you don't do it correctly. The problem with backstab connections is there are a multitude of ways to make it up poorly.Can we just agree that electricians shouldn't be calling receptacles, plugs?
If you remove the device that is back stabbed in the middle of the run the rest of the circuit is dead anyway so having the EGC still connected isn't doing much. I do agree that there are reasons why the EGC must be pigtailed but I disagree that backstabbing is a good practice.But the reason has nothing to do with safety and everything to do with paranoia. The reason you are required to pigtail EGC's is so that if you remove the device you won't open the EGC connection to the next device. backstabbed connections are every bit as safe as any other kind of connection if it is done correctly. You can make any kind of connection unsafe if you don't do it correctly. The problem with backstab connections is there are a multitude of ways to make it up poorly.
I'm inclined to agree that pigtailing EGCs has more to do with paranoia than reality.If you remove the device that is back stabbed in the middle of the run the rest of the circuit is dead anyway so having the EGC still connected isn't doing much. I do agree that there are reasons why the EGC must be pigtailed but I disagree that backstabbing is a good practice.
And to my point about there only being one ground screw on the device is that if there were a place to land more than one EGC installers would do it instead of pigtailing even with pigtailing being required.I'm inclined to agree that pigtailing EGCs has more to do with paranoia than reality.
Backstabbing gets a bad rap because it can be done poorly in a number of ways and often is. One of the problems is that it's not a good thing to do in a box that's not very deep because the wires get shoved up against the back of the box and can be moved around when the devices put in place. I've also seen people try and use it with stranded wire which is just a terrible idea or with conductors that have not been stripped to the proper length. What you are calling the back stab is just a terminal that is spring loaded. Spring loaded terminals have been around for a long time and by and large they are as safe as screw-in terminals if handled properly. Personally I don't like wrapping stranded wires around a screw and then tightening the screw down. There's plenty of potential for messing that up too.
Used to be and I'm sure still is code section that states something to the effect that continuity of the EGC can not rely on the installation of a device.If you remove the device that is back stabbed in the middle of the run the rest of the circuit is dead anyway so having the EGC still connected isn't doing much. I do agree that there are reasons why the EGC must be pigtailed but I disagree that backstabbing is a good practice.
Take a non metallic wiring method with multiple branch circuits installed but a single EGC. If you interrupted EGC by removing the first device you lost the EGC to all downstream components even if the circuit to that first device was all you turned off.
You can occasionally find old grounding type receptacles that had two grounding screws, I think even into late 1960's installs I have found these. Guessing the rule came about mid to late 1960's though because installs newer than that never seem to have such receptacles.
Sorry don't think I do. Seemed to be common to find them if still original installed device on old NM cable with reduced size EGC.Do you have a pic of these dual ground receptacles?
