electro7
- Northern CA, US
- Electrician, Solar and Electrical Contractor
I have a 208V wye on the utility side and 480V wye on the PV side. Both have neutrals XO and HO. I did run a nuetral conductor from the utility to XO. The transformer is bonded on the XO side but I have no continuity between HO and ground. I want to make sure I ground and bond this correctly. I am thinking I should disconnect the neutral landed on the XO and add a bonding jumper from HO to the can and grounding electrode. Does that sound correct?
The EGC on the 208V side would be connected to the HO as well in this case.
Sent from my SM-N960U using Tapatalk
