Grouch1980
- New York, NY
Hey guys!
Back with some other questions.
1. Are DC to DC Converters (located at each PV module) another way of saying Optimizers? Are they the same device?
2. Can DC to DC Converters decrease the total voltage in a series string of PV modules, in order to connect to the input voltage rating of inverter? Let's say you have 15 PV modules, each at 50 Voc. So the total Voc of the string is 750 Volts. (leaving out the temperature correction factor). Can the DC to DC Converter, located at each PV module, clip the total string voltage so that it falls below a 600 volt input rated inverter? If so, how does one go about calculating or choosing the Converter... is this something that's done by the Converter vendor, or are there any formulas / graphs one can use to calculate this?
3. What's a more typical installation being installed out there? Strings with DC to DC Converters? Or strings without them, and having to use combiners?
Thanks again!
Thanks again!
