I have a tenant metering system where the service is 120/208. There is a meter for each tenant that has a CT on each leg and voltage reference to the meter for each leg.
How does the meter calculate the apparent power in a situation like this? The load could be 120 V or 208 V. I've read one instance where it was stated that real power could be measured and then apparent back calculated. But either method needs to know the voltage components.
Thanks.
Thanks.
