Rex Hungerford
- Seattle
- Electrician
Is there anything saying I can not take a piece of 10/2 NM-B, paint the jacket with RF shielding paint, pull a mylar shield over it, wrap a drain wire around the mylar, cover it all in tech flex. The drain would only connect to the line side panel. The load side would be in a plastic box and the drain would be taped over.
Or the same situation but the NM-B jacket is wrapped in a RF shielding fabric, no paint, no mylar, then a drain wrapped over the fabric, then tech flex and landed the same as above.
Thanks
Thanks
