Theclash84
- Missouri
- Estimator
Hi All,
So I did something stupid.....I ran 12/2 romex on a 20 amp breaker to power a new circuit in my bathroom. I ran the wire to a new plastic box, pulled the wire into the box and stripped off the white and black both back about 3/8". Mind you, at this point the 20 amp breaker was wired to the breaker box, but in the OFF position.
I then attempted to flip the breaker ON. When I did this, BOOM! There was an arc of light about the size of my fist and the breaker immediately tripped.
I then went back to the black and white wires that were hanging out of the plastic box, they were touching each other where they were stripped, copper to copper contact. I created a short circuit.
I inspected the romex and there appears to be no visible damage to the cable jacket. I also pulled the breaker out of the panel, also no visible damage.
I then capped the black and white wires with wire nuts. Next, I turned the breaker back on and everything else on the circuit was operating correctly.
Without getting into why I turned the power on with the black and white wires not connected to anything...........
Should I remove and replace the romex? Could there be internal damage to the wire insulation? Should I replace the breaker?
