Jlewis7457
- Point Arena
- Electrical contractor
I have "step up step down" Installation for a single family residence that consist of a reverse fed 480v/240v/1Phase/ 37.5kva transformer, conductors are
(2) x #2/0 THHN Copper protected by a 200amp OPD with a #4 copper EGC. The feeder circuit between transformers is (2) x 1000' of 650mcm XHHW-2 AL and (1) x #2 AL equipment grounding conductor. The step down transformer 480v/120v 240v / 1 phase / 37.5kva at the house. ( Transformers are identical ACME transformers with multi-taps for fine tune adjustments, model # TP530193S
Questions:
1) confirm the size of the feeder EGC
2) will the neutral at the load side transformer jumper with the EGC
3) Is the service at the house considered 150amps
4) Can the load side of the step down transformer land on a 2 pole 200amp OPD in the first Sub-panel
Thank you in advance for your expertise and advice, JL
Questions:
