Highqelectric
New User
- New jersey
- Electrician
I install lights for everyone is it wrong to sell lights like I open a lighting company and sell customers my lights and install them
You can hide that markup in a fixed price much easier than you can hide it in a straight time and materials billing method.Light fixtures should be marked up if you furnished them or not
To add a little more to what I said before, the beauty of this is you maybe don't take as much markup as if you did furnish them, but at same time since you did not furnish them any warranty is limited to your installation methods and not to the fixture itself. That also means if called back because of a warranty issue, your time is still billable to remove/replace it where if you are the one warrantying it not so much.Light fixtures should be marked up if you furnished them or not
That seems a bit sleazy to me honestly. Personally, if I don't have to spec/source/purchase/pickup/warranty them, I'm fine letting customer pay, in fact that is my preference.Light fixtures should be marked up if you furnished them or not
Markup covers stuff that you do not think about that costs you money like handling time, reading the instructions, hardware, storage, etc. Just because someone else is supplying the parts does not mean that at least some of the markup should not be included to cover stuff you have to supply, but would not get paid for without at least some markup.That seems a bit sleazy to me honestly. Personally, if I don't have to spec/source/purchase/pickup/warranty them, I'm fine letting customer pay, in fact that is my preference.
Me too. Though I one time had client provide some pretty much junk troffers he got at big box store and really wanted to charge him extra just to deal with them. I guess since it was a T&M job it likely did cost him a little more in labor charges regardless.That seems a bit sleazy to me honestly. Personally, if I don't have to spec/source/purchase/pickup/warranty them, I'm fine letting customer pay, in fact that is my preference.
I just did a project where the customer supplied some pressure transmitters for us to install in a box. The original plan was for us to supply them, but as a cost savings measure they supplied them.Me too. Though I one time had client provide some pretty much junk troffers he got at big box store and really wanted to charge him extra just to deal with them. I guess since it was a T&M job it likely did cost him a little more in labor charges regardless.
I fully understand. I have little issues with customer supplying lighting fixtures such as pendants, sconces, chandeliers or others that the decorative nature is somewhat high priority. They are the ones that have to live with what they choose. I don't have to warranty them either, nor is it my fault if they don't like them.I just did a project where the customer supplied some pressure transmitters for us to install in a box. The original plan was for us to supply them, but as a cost savings measure they supplied them.
They gave us a parts list of what they were supplying. Of the twelve, only 4 of the units that came in were the part number that they gave us. Four of them had to be panel mounted (instead of valve mounted) and tubed up with barbed fittings that I did not have on order because the parts I expected would have had NPT ports. All of the transmitters were supposed to come with exposed terminals to wire to. Some did, some had pigtails, some came with a conduit box, and one needed a connector they did not bother to supply. This is fairly typical of my experiences with customers supplying parts, which is why I do not like doing it that way.
You probably need to be in a metro area for it to work out. Most your customers likely be high end home owners.Nothing wrong in starting a lighting showroom and sell and install them. Pursing same route. Thought I be open already but O well. Do you have any lighting manufacture in mind yet.
It has another perk, if customer is buying, paying for materials separately, it doesn't get added into your the calculations on the liability and WC audits and thus your cost for them., I'm fine letting customer pay, in fact that is my preference.
Might been cheap cans, but they probably still had wrong lamps in them, that may be harder to convince them than that they are cheap cans.Back when cans first came with thermals a customer wanted me to work on cycling fixtures they supplied. Nope, not after the first diagnosis.
Lamps were correct. Thermals were still in their infancy. IDR brand of cansMight been cheap cans, but they probably still had wrong lamps in them, that may be harder to convince them than that they are cheap cans.
