James L
- Kansas Cty, Mo, USA
- Electrician
I have a service upgrade on a job I took over behind another electrician. He roughed in a basement, then I finished it. He planned a service upgrade from 200 to 300 and added a 100 amp MLO panel across the basement, next to existing 200 amp MLO panel
First picture shows what it looks like now on the outside. Notice a 2-2-2-4 SER stubbed out under the existing 200 amp disconnect.
Second picture shows my first plan:
Orange = 400 amp meter can
Blue = new 100 amp main breaker disconnect
Green = gutter out of meter can, nippled up into each disconnect, with SER also through gutter.
Now they want to add backup generator.
Problem is wall space and possible logistical issues
Third picture shows (in yellow) 300 amp ATS and disconnect. Also in yellow is powwr from meter to ATS. Then in white is power from ATS to that gutter and into disconnects. Gutter would no longer attach to meter can.
But if you notice, the only wall space is on a cantilever. I think I would need to hang the generator equipment low, so as to come in and out of the back of the ATS.
Wondering if it would be better to just hang strut down off the house only low enough to mount equipment, or take the strut all the way to the ground so I can attach pipe to it.
Also curious about how someone would get gas line across all those pipes/phone/catv
I don't know exactly where generator will sit, but more than likely close to all that stuff.
Just looking for thoughts.
Maybe someone sees something from a different angle that might help.
