sparky1118
- Massachusetts
- Master Electrician
I’ve been wiring a house on an island for the past few weeks. Turns out I failed the rough inspection. For two reason
first one was the kitchen counter outlet was within 24” of the kitchen sink. The second one was I used SER cable for the service. The ceilings in the basement are fairly high for around here. They are about 8’ ceilings. I came in with my SER installed plywood to the wall and secured the SER before it entered the panel. However since it is in about 2-3’ of contact with the cement foundation before it hits the plywood that is against code and said I need to install a 2x4 going vertical to protect the SER from touching the foundation…. I knew he would find something to fail me for since I’m an out of town electrician.
Sent from my iPhone using Tapatalk Pro
