cbooker
- Dallas, TX
- Electrical Contractor
We recently completed a Generator installation, and the inspector was pulling on the Generator Feeders wires at the Automatic Transfer Switch until they broke loose. My onsite electrician told me that he tugged on them with both hands at the Transfer Switch until it broke loose at the terminal. He then failed the inspection stating that the wire lugs were too loose for the inspection. The inspector pulled on a Metallic Seal Tight Connection in a similar manner until that broke loose as well and then stated that the seal tight connection was also loose.
I am very familiar with Torqueing lugs to spec based on Manufacturer recommendations, however, what do we do if the OEM torque spec isn't strong enough to resist a grown man tugging on a Seal Tight or Power Feeder Connection? I don't believe there is a "tug test" requirement anywhere in the NEC code book stating a wire or seal tight connection must withstand 100lbs or 50lbs of downward force at the terminal or seal tight connection? Is there something that I am missing here? Any help in this matter would be greatly appreciated. Thanks!!
