Phil Timmons
- DFW
- Depends on the pay and the day
I suppose that would 240V, 15 Amps each side.How are they getting 240V? Are they assuming everyone has 2- 120v receptacles on different phases right next to each other?
I'm assuming since they say "Generator/Welder" in the description, that they are planning on folks using it on welders or generators that have a double duplex on the front panel, each of which is a typically different phase, so it would actually give you what you need. If the generator has a 14-50R on the front panel....it's wired exactly the same behind the panel so....I'm not sure what the big hoopla is about this.How are they getting 240V? Are they assuming everyone has 2- 120v receptacles on different phases right next to each other?
Well there you go. We should take their EVs and THEM and dump both in the ocean.Folks are getting these to plug Level 2 (240V, 30 Amp) EV chargers in to household circuits . . . .
(laughing -- thanks, I could use that today)Well there you go. We should take their EVs and THEM and dump both in the ocean.
[/thread]
Why so hostile to the future? Gas cars are slowly on their way out.Well there you go. We should take their EVs and THEM and dump both in the ocean.
I looked and don't see such a question. I think it either did not get posted yet or got deleted.I posted a question asking if it is UL listed and whether it can be used and still meet NEC requirements. I know the answer, I just want to see them respond to it...
For maybe about 5 or 10 seconds -- depending on the trip time of the breakers? ;PExactly how would one derive a 240V/30A circuit from two 120V/20A circuits?
it might take quite a while for the trip to happen. If I understand it, the 30 A version only uses 24 Amps max.For maybe about 5 or 10 seconds -- depending on the trip time of the breakers? ;P
Don't even get me started, Wayne. I'll get banned for derailment. When all the electric vehicles get charged 100% from Solar or wind, then maybe they will take a step toward lowering the carbon footprint. Until then, it's absolutely nothing shy of total hypocrisy. $.02Why so hostile to the future? Gas cars are slowly on their way out.
Cheers, Wayne
Perfect. This should allow the cord and plug to brown and toast very nicely . . . . ;Pit might take quite a while for the trip to happen. If I understand it, the 30 A version only uses 24 Amps max.
This is for a QOU breaker. Probably most are very similar. 125% of 20 Amps is 25 Amps. So it might never trip.
10,000 seconds is almost 3 hours.
Because . . . . Oklahoma. You would have to be around this to understand how funny it is.Why so hostile to the future? Gas cars are slowly on their way out.
Cheers, Wayne
You want to really pi$$ me off? Bring up those big, hypocritic things that are eating up the landscape around here...leaking oil down the risers into the farm ground. Work 20 years buying 160 acres to build a home, live, work, and die on....then these big pieces of S(*$ show up and now everyone gets to look at them every day...and their damned blinking little red lights all in harmony every night. Screw them stupid white things. No wind, no power. Too much wind, no power. Half of them are turning most of the time. It takes more energy to produce one of them than that turbine will ever produce. Mark my words. In 20 years from now, they will all be ran down, out of commission, and left in the air to root in people's fields. People buying into this "free money" are going to get the biggest "I told you so" ever.It is funny, and it is Oklahoma. ;P
But if you want to insist on sensible and real -- there is this >>>
If the receptacles are on 20A circuits then an EV or dryer on a 30A plug might continuously pull 24-26A without ever tripping. But if either receptacle is on a 15A breaker it will probably trip at less than 5 mins at such amps. In the latter situation you might get away with it for a welder or other power tool that you don't run at full amps for 5 mins.For maybe about 5 or 10 seconds -- depending on the trip time of the breakers? ;P
Well considering they probably just take your money and never really send anything . . . that is just about perfect.If the receptacles are on 20A circuits then an EV or dryer on a 30A plug might continuously pull 24-26A without ever tripping. But if either receptacle is on a 15A breaker it will probably trip at less than 5 mins at such amps. In the latter situation you might get away with it for a welder or other power tool that you don't run at full amps for 5 mins.
Problem is, the product shown actually has a 50A plug. A Tesla or other plug-in EV charger will think that it can draw at least 32 if not 40A on that. The latter should trip in a matter of seconds.
