a 100 unit apartment building has units that have 2-pole 40 amp breakers at 208V single phase. Only 1 meter feeds all the apartments and they want each apartment to be metered.
There are 2 panels that feed all the apartments. Each panel has 2-pole 40A breakers feeding them.
I would like to install the meter banks but the minimum breaker size for each meter is 60A so I can’t just refeed the 40A with a 60A breaker because i would need to upsize the entire 40A wires to accomodate the 60A breaker.
Is there any easy way to refeed the 40A apartments with 60A without upgrading the entire 40A wire?
I can’t just use a 60A wire on the line side of the 40A breaker because the panelboard won’t let me do that.
