Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
In Mike Holts video regarding theory and operation of surge arrestors, it is stated by Mr. Holt that surge arrestors protect load devices downstream by clamping or limiting voltage potential level.
He states, these surge protectors contain a semiconductor in parallel path to the circuit being protected under cases of excessive voltage or lighting induction (mutual or direct contact). When exposed to high levels of voltage (300 volts or more?), the semiconductor in the surge protector connected in parallel to the circuit changes from an insulator to conductor and allows this excessive voltage to take this path and return on return path, neutral load leg.
Apparently, this causes such a high current that voltage is lowered or limited or “clamped” shunted on the circuit to loads to protect them.
However, in another credible source on electrical theory in the form of a text book (siting of source available upon request), it is stated that rules of parallel circuits follow that VOLTAGE IS CONSTANT, while amperes very per leg in parallel.
This I have also tested back in my old days as an ASE L1 Advanced level automotive electrician with a 94 Ford F-150 4.9L motor having 3 fuel injectors wired in parallel. When one injector went bad, the voltage remained constant BUT it’s individual AMPERE draw varied from the rest of the injectors.
Therefore, the old saying was that current travels ate the point of least resistance, but modern saying is that current takes ALL PATHS. Additionally, if we are following the rules of parallel circuits, how then can voltage be shunted or reduced to protect loads downstream from surge protectors since voltage remains constant in parallel circuits? Thanks
