RatherBeFishin
- New York
- Electrical apprentice
Curious if anyone does things differently when working on a live ckt.
I was taught in terms of the HOT wire, that it’s the “first to break” and “last to make” so disconnecting hot, neut, then ground.
And connecting ground, neutral , then hot
Or
with the GND wire in mind which really is the same exact thing,
It would be “last to break” and “first to make”
Found it interesting to know that a couple guys I know, when they’re feeling too lazy to find the breaker and changing a switch or outlet like hook the ground up last so when connecting the hot if it it hits the yoke on the device doesn’t arc and trip the ckt. I see the point but to me that’s the whole point that you want the ckt to trip and not have current go through you instead if you happen to be touching the grounded box, or your screwdriver comes in contact with the box, or your leaning on a ceiling grid, or leaning on building steel, etc
Wanted other sparkys feedback on the matter.
Disclaimer: we all know to find the circuit and never work hot under any circumstances is the right thing to do here. I’m sure we’re all guilty of not practicing this a time or two though lol
Or
