Coppersmith
- Tampa, FL, USA
- Electrical Contractor
A few days ago I did a service call here. There is a smoky smell in this panel. Nothing (including the main) feels warm. I removed all the branch breakers and inspected the breakers and the bus. The only damage I could find was under a two-pole twin (4th and 5th breaker on left side) where a plastic fin on the bus was melted. That 20 amp breaker is connected to a 18.75 amp water heater. I replaced the breaker and relocated it to a spot with more air circulation.
The panel is in a closet. I closed the door and turned off the light. It was pitch black in there. I could see no arcing or flame. I found no terminations that were loose.
Last night the client was watching TV in bed so I suspect there was a light total load. The 150 amp main breaker tripped. I'm at a loss as to what could be causing the issue. I'm thinking there is a main breaker failure of some sort, but like I said the breaker was cool to touch when I last checked.
I'm heading over there soon. I'm hesitant to change the main without knowing the cause. Please give me suggestions, Thanks.
