ESolar
- Eureka, CA Humboldt County
- Electrician/Contractor
This topic has been hashed out many times. Even so, I still feel that I don't understand how to make a code compliant transition from an interior wall through the back of an exterior surface mounted breaker box. My issue is with the entrance through the back - I want a code compliant transition through the back, without vertical sleave from the top of the panel to the attic.
Apparently, the local AHJs allow the wires, even NM, to run through one big chase nipple through the back (provided they are attached to a stud within 12" of the chase nipple). This job has UF and SER so the wires are rated for wet locations - no NM. But my understanding is that a bunch of wires through a chase nipple is not compliant.
Wires: #6 AL SER, 2 x #8 CU SER, 1 x #12 UF, and 2 x #14 UF.
Panel 125A 8/16 surface mount
So how does one perform code compliant wire transition from the interior of a 2x4 wall (stucco exterior) through the back of the exterior surface mounted panel? Does it require an individual chase nipple for each wire? If so, sounds messy, hence the vertical sleave.
If not possible, what are the other alternatives? Conduit from the bottom or lower sides? What is the preferred method?
