Stevenfyeager
- United States, Indiana
- electrical contractor
My customer has a pole barn, used for a business. I have a commercial permit to install a 400 amp service using two meter disconnect combos. One 200 amp panel will go in a bay about 80 feet from it's disconnect. ( up12' then across 40 feet ceiling then down12 feet.) (ceiling is 16' high) I do not do much commercial work. Inspector says I must apply 230.50 protection for this. I'm assuming using 4/0, 4/0, 4/0 Al. Is EMT advisable ? 2" ? Would I use the conduit as the ground ? Thank you.
