JoesBagelandDeli
- Chicago
- E Eng
A couple of weeks ago, I reached out to the architect and requested that they update their elevator spec to identify a minimum SCCR of 35kA. They then sent that revised spec to their elevator vendors. The most positive response we received was that it'll cost a significant amount of money while others simply said they can't do it.
I feel as though I have two options at this point if the best SCCR for an elevator controller we can assume is 10kA.
Option 1:
Feed this off the 208V distribution where the available FC falls below 10kA.
Downside: Larger breaker and conductors, and will likely push low-voltage transformer into next size up= more money
Option 2:
Feed this off of the 480V distribution where the available FC at the elevator is ~32kA.
Provide a fused disconnect with current limiting fuses, and direct the elevator manf. to not include an OCPD within their controller and/or disconnecting means.
Downside: The use of CLFs appears to be a contentious topic on this forum and elsewhere. Many people whose opinions i respect on this forum seem to not be willing to sign off on their use - per 240.86(A).
Are there other options or considerations?
Option 1:
Option 2:
