wiring a barn house
Stevenfyeager
United States, Indiana
electrical contractor
I will look at barn house this week. Planning on running everything in conduit. But for areas above 8', I suppose we could run UF without conduit like we can in livestock barn ?
The code does not say that cables over 8' high are proteced from damage. It will be your inspector's call as to what is exposed to physical damage.
For esthetics I would personally want to do it in K&T, but I'm sure someone official would have a problem with it
I saw the barn house. Sure enough, log walls, finished wood ceilings. All exposed finished wood surfaces. One exception. All around the log walls, he left out the mortar of one row (chinking they call it I believe) for me to run wiring horizontally. Is it ok to run UF in there ? The 'chinking' that will surround the UF is brick mortar. Is UF rated for that ? Thank you.
I thought you can't put non metallic cables of any type in mortar. You can put mc in there if it's wide enough though.
Should have called you before they built it. Either the log stackers could have drilled holes for you or you be there to do it. My price would go way up, or I would refuse to wire a log house after the walls were up. Hard enough when holes are there, then you have to notch the logs for boxes. If they are "D" logs you would also have to leave a flat spot for the face plate to sit flush.
I think he should try to sell them on black or brown painted emt. It's the only thing that'll look good at this point
Is this new construction? I was picturing an old barn made into a house. Yeah I'd just do all emt.
I can't believe someone would do new construction and leave the electrical as an afterthought
