2023 NEC Codebook
infinity
New Jersey
Journeyman Electrician
I see that the spiral bound 2023 NEC is offered on the NFPA site for $161.00. I also see that Walmart has a version for $39.98. I'm assuming that these cheap versions are printed on extremely thin garbage paper hence their exceptionally low price. Has anyone purchased one of these cheap versions of the book? I'm looking for a spiral bound book that can be dissembled and run through a scanner. I'm curious if these cheap books have paper so thin that the words will bleed through when scanning or worse they will get jammed up in the scanner.
don_resqcapt19
Illinois
retired electrician
Even the paper in the softbound version is thin enough you will get an overall gray tint to the pages.
I send a soft bound copy to a company that scans books and they cut the binding off, scanned the pages and returned a PDF copy. They used OCR to make it searchable, but there are typos because the OCR is not perfect.
If the paper is thinner than that in the soft bound version, I think it could be a problem.
RdmanElect
Poughkeepsie NY
Electrical Contractor
I purchased a spiral bound from amazon and there's ALOT of typos. I recommend going through the NFPA website. Especially if you use that same book on a test
Ponchik
CA
Electronologist
Which company do you use? I like to get my handbook done.
infinity
New Jersey
Does anyone know how the NFPA is even allowing this? And why would there be typo's is someone actually re-typing the entire book?
Sea Nile
Georgia
I saw the same problem buying a cheaper NFPA Handbook off of Amazon. It was hard cover and looked official except for all the typos. Even had the NFPA water mark on each page.
I think they are scanning and not re-typing the book.
My thought as well so why the typos?
I don't know much about the printing industry, but seems strange that they would be scanning it (unless it's a black market copy). So some entity wants to print and sell the book, and the NFPA says ok go find a paper copy and scan it??? Maybe they want it that way so it's lower quality so there's a reason to buy the more expensive one?
Another C10
Electrical Contractor 1987 - present
Southern Cal
Electrician NEC 2020
From which site and why did it take several tries?
I left the link on prior post, my phone timed the download out it seems with the apps numerous pages. it is only for many updated codes, not all. They're are other code apps it seems that are the entire code book but naturally it's 2-12 bucks
don_resqcapt19
Illinois
retired electrician
That makes sense. I was thinking that each page was scanned as something like a .pdf but that might change the searchability.
If you just scan it as a pdf without OCR, I don't think you can search it. However that would be an exact copy without the OCR issues.
W@ttson
USA
I bought the cheap one from eBay. You are correct. The paper is very poor and thing. It shreds a bit when flipping the pages around the spiral. I use it sparingly because we also have a subscription to NFPA link so I end up using the spiral when I just want to feel a hard copy in my hand. Sometimes I end up getting less lost like that in the code when there are a lot of back and forth references.
