ericwg
- Sacramento, CA
- Associate Electrical Engineer
2022 California Title 24, Part 6 (Non-residential) Section 130.5(d)(2) states the following:
(d) Circuit controls for 120-volt receptacles and controlled receptacles. In all buildings, both controlled and uncontrolled 120 volt receptacles shall be provided in office areas, lobbies, conference rooms, kitchen areas in office spaces and copy rooms. Additionally, hotel/motel guest rooms shall comply with Section 130.5(d)4. Controlled receptacles shall meet the following requirements, as applicable:
2. Install at least one controlled receptacle within 6 feet from each uncontrolled receptacle or install a splitwired receptacle with at least one controlled and one uncontrolled receptacle. Where receptacles are installed in modular furniture in open office areas, at least one controlled receptacle shall be installed at each workstation;
I would like some clarification on the first sentence of 130.5(d)(2). To do so, let's assume we're looking at a long section of a given wall where I have four 120V duplex receptacles installed. I believe what 130.5(d)(2) says is that I can employ one of the following options:
a) Have the OS control every other duplex receptacle, i.e. every other receptacle will shut off completely (both outlets), OR
b) I can install splitwired duplex receptacles throughout the room whereby the OS will only turn off half of every receptacle (one outlet)
Is that correct?
The reason I ask is because I have seen designs where an OS controlled splitwired receptacle was only installed EVERY OTHER receptacle. In other words, the first duplex receptacle would not be OS controlled, while the next duplex receptacle would be splitwired, where the OS controlled half of that receptacle (one outlet). In other words, running down the wall (from my previous example), of the first two duplex receptacles encountered, only one of the four outlets would be OS controlled. These were stamped/approved plans. Honestly, given the way 130.5(d)(2) is written, I can't fault someone for interpreting it this way. Or, maybe they were right! Thoughts?
Is that correct?
