BHastings
- San Diego, CA
I am a contractor in CA and we just these lists of banned electrical panels and breakers from a condo HOA.
First carrier gave this list:
The second carrier gave this:
There is no need to talk about FPE at all.
The same with small frame Zinsco breakers.
Now Zinsco did not make their own large frame breakers, there is a lot of switch gear and meter distribution panels with GE breakers. I don’t think these were ever part of investigations into Zinsco’s issues. I don’t think a Zinsco placard on one of these sections of gear should make that assembly bad.
Going into old buildings and pulling out old gear with new will 98% of the time never fit in the old electrical rooms.
I have not seen issues with Bulldog products other than they often don’t like to reset, but never from a failure to trip.
But if you are now going to ban:
ITE Siemans
Challenger
Square D
I was shocked to see Square D make this list.
This is the 6th HOA or property management group that has come to us in the last 4 months concerning both residential and commercial properties.
We are left with:
Eaton gear, panels, and breakers.
Old Westinghouse gear.
Leviton panels and breakers.
Small regional independent manufacturers?
Your feed back is greatly appreciated.
![1718024705062.png 1718024705062.png](https://forums.mikeholt.com/data/attachments/35/35700-33218de3cf3c6c7e3a47f8517b1efcbd.jpg)
"As long as you are reviewing the building equipment, these are the circuit breakers with high failure rates:
Federal Pacific Breakers/Stab-Lok
GTE/Sylvania products (some)
ITE/Seimens/Bulldog Pushmatic
Zinsco, including Zinsco compatible breakers such as Kearney
It is also important to confirm that your structure also does not have the following:
Non-pigtailed aluminum wiring
Square D Panels
ITE Siemans
Challenger
Square D
We are left with:
