new-master
- MARYLAND
- ELECTRICIAN
I got a call from Customer who said that their transformers going bad and it’s not putting out the 208v as it should only 193v
But also the room temperature really warm about 95°F top of transformer enclosure
There are three water heaters & a furnace in this room.
Could the heat be the cost of the voltage drop.
I put a fan on the transformer and the voltage has risen 200volts and temperature above transformer enclosure 93.5°F
Utility voltage coming in each phase is 267-269v
A-B= 463v
B-C= 463v
A-C= 468v
Please help what should I do on this situation?
