- Chapel Hill, NC
- Retired Electrical Contractor
There was a change in this section to clarify the concept of 6" of wire in a switch box.
In the following video this guy seems to say that you can splice one wire and make it longer but you can't put 2 conductors together and extend with one wire. It makes no sense. He said he got his info from Paul
The video is short and you don't need a facebook account although it will pop up and ask you to sign in.
www.facebook.com
300.14 Length of Free Conductors at Outlets, Junctions, and Switch Points
At least 150 mm (6 in.) of free conductor, measured from the point in the box where it emerges from its raceway or cable sheath, shall be left at each outlet, junction, and switch point for splices or the connection of luminaires or devices. The 150 mm (6 in.) free conductor shall be permitted to be spliced or unspliced. Where the opening to an outlet, junction, or switch point is less than 200 mm (8 in.) in any dimension, each conductor shall be long enough to extend at least 75 mm (3 in.) outside the opening.
Exception:
Conductors that are not spliced or terminated at the outlet, junction, or switch point shall not be required to comply with 300.14.
33K views · 1.9K reactions | NFPA responded #electricianofinstagram #electrician #nationalelectricalcode | Stevenj120volts
NFPA responded #electricianofinstagram #electrician #nationalelectricalcode.
