300.3(B) Conductors of the Same Circuit.
All conductors of the same circuit and, where used, the grounded conductor and all equipment grounding conductors and bonding conductors shall be contained within the same raceway, auxiliary gutter, cable tray, cablebus assembly, trench, cable, or cord, unless otherwise permitted in accordance with 300.3(B)(1) through (B)(4).
Why not just keep the two neutrals separate? What are you trying t accomplish?The title asks the question. I have a single 12-2 running to an outbuilding. I want to make it a MWBC and put on a 2 pole breaker. Can I run another 12-2 and use the two cables or do I have to abandon the first run and just use a 3 wire cable?
IMHO... Running two separate 12/2 cables would put the neutrals in parallel. That would be a violation.The title asks the question. I have a single 12-2 running to an outbuilding. I want to make it a MWBC and put on a 2 pole breaker. Can I run another 12-2 and use the two cables or do I have to abandon the first run and just use a 3 wire cable?
If you used both that way, yes.IMHO... Running two separate 12/2 cables would put the neutrals in parallel. That would be a violation.
What's happening with the two whites (which cannot be paralleled) in the outbuilding?Scenario
2 cables 12/2 going to outbuilding. In the panel of origin splice the 2 neutrals and add 1’ white 12 awg conductor to neutral bar.
Land each ungrounded conductor on a 2 pole breaker.
You have a mwbc supplying outbuilding.
Magnetic fields cancel each other out in each cable .
No different than 12/3 to j box and separating with 2x 12/2s
Really reaching, Splitting at the other structure is way different from splitting just past the breaker. All conductors of the MWBC shall be contained within the same cable2 neutrals are connected to 1’ of white 12 awg conductor in the panel of origination. So the circuit starts as mwbc .
How is that any different from the two neutrals being landed on the neutral bar. I do not see that as any part of a MWBC.2 neutrals are connected to 1’ of white 12 awg conductor in the panel of origination. So the circuit starts as mwbc .
Splicing on a short pigtail for the two neutrals makes it a 3-wire circuit instead of two 2-wire circuits. The 3-wire portion of the circuit meets the definition of a MWBC.How is that any different from the two neutrals being landed on the neutral bar. I do not see that as any part of a MWBC.
