Joethemechanic
- Hazleton Pa
- Electro-Mechanical Technician. Industrial machinery
Interesting, but the closest this cable ever came to CAT anything is when a stray had kittens in that old telephone closet. It's probably 1960's.![]()
Cat 3 Vs. Cat 5 Cable | Techwalla
Category 3 (Cat-3) and Category 5 (Cat-5) cables are two of the most widely installed categories of data transmission cables under standards devised by the Electronic Industries Alliance (EIA) and the Telecommunications Industry Association (TIA).www.techwalla.com
So you want Ethernet and PoE over non twisted pair cables? Good luck with that. New CAT5E or better cable will be needed.Interesting, but the closest this cable ever came to CAT anything is when a stray had kittens in that old telephone closet. It's probably 1960's.
I wonder how much different the construction of the cable is.
Basically I want to add a couple of wireless access points
I thought those were twisted pairs. Been a while since I've stripped the jacket off of anynon twisted pair cables
They are. The problem is that the number of twists per inch is related to the frequency that the cables can reliably carry, which is based on common-mode noise rejection at the receiving end.I thought those were twisted pairs.
Don't know your situation or layout requirements, but you might consider replacing the cable with wireless radios.Basically I want to add a couple of wireless access points
They use it for ADSL, around 12 meg if you are lucky. 1 mile limitation.I'm talking about this stuff. It's already there and going exactly where I want to go. It's a lot of work saved and I'd have to get a scissor lift in here to run modern CAT cable.
View attachment 2581893View attachment 2581894View attachment 2581895
Use a lot of those, there is a company that also pre sets them for plug and play. 10 mile range. Just upgraded a switch at a customers building. Got about 30 cameras too. Domes, PTZ and bullets.Don't know your situation or layout requirements, but you might consider replacing the cable with wireless radios.
Then you can also add extensions, from them with cables if needed.
I started with them years ago, linking between buildings and then adding access points inside when needed. for extended coverage.
You can start the learning process here. If interested. They have made great products that I have used outdoors and indoors for decades. ps://www.ui.com/us/en/how-it-works
the new products store for perusing. https://store.ui.com/us/en?s=us&l=en
Here is one of the older obsolete models I started with, for cheap never had one fail with years of outdoor use.
You might get away with one inside depending on your requirements and layout
Ubiquiti Networks NanoStation LOCOM2 2.4 Ghz Airmax Wireless Access Point for sale online | eBay
Find many great new & used options and get the best deals for Ubiquiti Networks NanoStation LOCOM2 2.4 Ghz Airmax Wireless Access Point at the best online prices at eBay! Free shipping for many products!www.ebay.com
Right now I have about 10 Mbps in the office on a good day. 15 tops. But I'm having Frontier 500 Mbps installed, and I want to get as much speed as I canHere is a speed test across the lot, thru a block wall and another shop, to the older DSL wireless router, plenty fast enough for my needs. I'm sure it would be faster if the basic router on the other end was a faster unit and line in. Don't know how much throughput you need, but for older gear this is not bad. I'm not sure even what the DSL line and router is rated at.
Well, I have no experience with a fiber front end. But it advises that advertised speeds are wired, actual speeds vary. Maybe you should have them run the fiber across the building if you want full throughput. cat3 certainly is not what your looking for.Right now I have about 10 Mbps in the office on a good day. 15 tops. But I'm having Frontier 500 Mbps installed, and I want to get as much speed as I can
Didn’t Frontier get bought by Verizon? The industrial customer I have has Kinetic fiber ( one step above Frontier, not saying much) and Starlink as a backup.Right now I have about 10 Mbps in the office on a good day. 15 tops. But I'm having Frontier 500 Mbps installed, and I want to get as much speed as I can
