jakeparsons03
- USA
- Engineer
Let's say you are putting together a motor circuit with DOL starter contacts.
In Section 430.1 of the NEC it shows the order as Motor branch-circuit short-circuit and ground-fault protection device -> Motor control circuit -> motor overload. From that I would think the order would go, Supply -> Magnetic Component -> Starter Contacts -> Thermal Component -> Motor. If you are using a MPCB with Thermal and Magnetic components combined under one device, which side of the starter contacts do you put it on?
Also, I know there are more components to the circuit described above, I am only concerned about this portion at the moment though.
