mrh335
New member
- chicago, IL Lake County
I am trying to gain a better understanding of NEC 810 and 820 for the proper installation of the satellite dish.
It was installed in a way which I now see being questionable.
My installation has a TV antenna on the roof and a DirecTV satellite dish mounted about 10 feet up on the side of my house. A 10 AWG insulated copper wire runs from the antenna down to a grounding block. A 10 AWG insulated copper wire also runs from the dish to the grounding block. The grounding block was then connected to a cold water line inside the house about 5 ft away. I have reconfigured the plumbing and no longer have that water line and therefore need to ground everything better and I am now seeing the way it was done may have been incorrect from the beginning. I want to fix this correctly.
In addition, my main electrical service and ground rod are on the opposite end of the house about 50 feet away.
From what I have read in NEC there is no length requirement to the wire coming from the dish or antenna to the grounding rod. I am guessing I should then extend these wires around the house to the ground rod directly and use a home run for the dish and a home run for the antenna.
Please advise the correct and easiest method to safely ground my equipment.
- In this setup, do I have to run a whole new wire from the antenna or can I splice a wire from the ground rod to the wire from the antenna in a terminal block in the COAX POE to the house and continue the ground wire around the house to the rod?
- Is my interpretation correct that I need a home run for both items or can I combine the dish and antenna to a single wire which runs back to the ground rod?
- The NEC states the COAX should be grounded as close to the POE as possible. Would I be able to run a 10 AWG insulated wire from the COAX grounding block 50 feet around the house to the ground rod or is this too far?
