- Illinois
- retired electrician
Is there any documented evidence that using the re-bar as a concrete encased electrode will cause concrete failure under high current conditions
I was told that this a is an issue and that I could solve the problem by adding a couple of ground rods. I told him that one, the grounding electrode should not be carrying very much current in the event of a fault, and two, even if this is an issue, the relative impedance of the ground rods would be so much greater than that of the CEC that it wouldn't make any difference.
He responded that he was talking about lighting strikes. He cited some issues with concrete bases for high voltage tranmission towers where the re-bar in the bases was used as a grounding electrode and it was causing the concrete to be damaged when the tower was hit by lighting. He said adding the ground rods prevented this damage. I seem to recall reading a bit about this, but that the fix double tying or welding the re-bar, not ground rods.
He also said that the use of the re-bar as a grounding electrode causes the re-bar to corrode and as it corrodes, it gets expands and caused the concrete to crack or break.
I have not seen any papers discussing these issues, and wonder if they are real world issues, or what?
