cdcengineer
We are working on a job where a UFER or concrete encased electrode was going to be used in addition to structural steel and the H2o pipe to make the grounding electrode system (GES). However this building is different than many I have been involved with in the past. The footers where the CEE was going to be located are poured on top of compacted gravel. I always thought that the UFER must be in direct contact with "earth" meaning dirt. The vertical foundation is made up of precast walls which just appear to set on top of footers and the exterior will be back-filled with gravel (not dirt). So it's my understanding that we can't use these walls as CCE. Perhaps this is just my own preconceived notion, but can someone set me straight? Are dirt, gravel and earth all the same in the eyes of grounding?
Next, the structural steel is attached with hold-down bolts, but these bolts do not tie to any rebar in the concrete encased electrode (CEE) so it's my thought that building structural steel is not "present" as an available electrode per 250.50. It seems as though the miles of structural steel would need to be part of the GES, but how can the steel connect to the CEE without tie between the hold-down bolts and rebar?
Thanks for the feedback
