nullsig
- Louisville KY
I work at an industrial facility and we are replacing ~20 year old UPS systems that provide power to critical process control equipment, network racks, and servers.
Currently these systems/loads are not on an isolated ground but the question was raised as to if we should implement an isolated ground when replacing the old UPSs.
Is there a convention or recommendation for when isolated ground is appropriate? As I said before, these systems have been in for ~20 years and we haven't had any grounding or noise related issues to date. However, I feel newer electronic systems are becoming more sensitive so it is prudent to address the issue.
Some of these loads are "dual sourced"- they have ATSs with normal power and UPS power inputs, or particular equipment might actually have two separate power inputs/power supplies for UPS and normal. Are there any consequences or considerations for dual fed loads when one of the sources is on isolated ground and the other is not?
