chrisreisinger79
- Grand Rapids, MN, USA
I work as a maintenance electrician in a metal foundry. A new piece of equipment in the lab requires an isolated ground. The panels here are from the 70's and there is no ground system at all beyond the neutral. I am adding an isolated ground bar and pulling a #8 to a ground rod outside. I am installing another ground rod 6' from the other to ensure the resistance is low enough for the sensitive piece of equipment. Can I keep the 8 wire continuous through the 2 ground rods? Does the wire between the 2 rods need to be bare?
