Announcement
Collapse
No announcement yet.
Voltage drop problem
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Dear Team,
    Please assist me as per the following explanations,
    I spent last night and this morning stripping my systems apart to try and see if I could find any faults.
    Can you please help me and advice testing/fault finding equipment to verify our equipment provided
    1 X 33KV Ring Main Unit
    1 X MVA Transformer
    1 X 500KVA Transformer
    Within the port we have a RMU distributing to 2 X Transformers, from these we have LV panels with a backup generator (change over switches in place).
    When we are running through Utility
    L1/N is showing 170V
    L2 /N is showing 237V
    L3/N is showing 359V
    N/E is showing 117V
    Running through generator
    L1/N 241V
    L2/N 237V
    L3/N 239V
    N/E 12V
    This leads me to believe that there is a poor connection between our N and the incoming Transformers, this will mean our N is not held to our earth potential. This fault has only just developed, so we need to find the reason.
    What can be the possible causes??
    #2
    Looks to me you already suspect the correct cause...
    Poor if not non-existent N-source connection will allow LN-load voltage to float, even when it has solid GE connection.
    [COLOR=RoyalBlue]I will have achieved my life's goal if I die with a smile on my face.[/COLOR]
    Comment
      #3
      I had the same thing happen but for a slightly bizarre reason.
      Two electricians unfamiliar with the layout of the main panel disconnected the NE jumper to make way while they pulled a new cable in, they then reconnected the jumper and left. In the mean time all the office equipment had been toasted. As I’d installed the panel and 500kVA transformer I was sent to investigate, I couldn’t find anything wrong as the gruesome twosome had left. It took a chance conversation over lunch days later to find out what had happened.
      [COLOR=#000000]The reports of my death are greatly exaggerated.[/COLOR]
      Comment
      Working...
      X
