Aidan
New member
- Saylorsburg PA
How far does the service ground rod need to be from the lightning protection ground rod and am I correct in saying that for the service which is 200 amps a second ground rod is not necessary if resistance is less than 25 ohms and is this resistance tested on just the rod or both rod and cable back to panel
